screamin reel
Here's my attempt at some rockers / skis.
I wanted something with the OEM rocker look but a little beefier.
Got the idea from Steve here on the forum AWS. Thanks for the pics Steve.
The guy that was going to bend the metal for me couldn't so I had to cut & weld myself.
Since I only used 1/8" plate I needed a little bracing on the inside. I'll also weld on the OEM rocker top to gain the look a bit more of the original look.
I'm thinking of also adding the rounded nerf bar. What do you think. Yes or no ?
Would you change anything with this set up ?
Thinking of cutting them in line with the flare.
