Benny
I recently bought a Bronco and have decided to go a different direction on the front bumper that it came with.
It is all aluminum with a Warn 8274 winch. The bumper will need custom mounts to attach. The previous owner had welded 1/4 steel plates to the frame with a couple of holes for attachment points. The bumper also has two holes per side where the had lights mounted. One for mount and one for wiring. It is a little oxidized but will clean up well.
The winch is a Warn 8274 that will need a complete overhaul. (It was this way when I got it.) It appears the previous owner took it apart due to a bad motor but then it never got put back together. I am assuming that besides a motor it will need all new seals and probably a new gear in the clutch assembly due to being left outside and rust.
