Custom Dash Wiring
kiteoregon
I have cut up and painted my dash and working on install of the Automated gauges and misc rocker switches. Anybody have pictures of the wiring and more specifically of a clean way to connect the grounds and common power wires. I was thinking of using butt connectors with 2 wires in one side, and the single feeding the next gauge etc. Just looking for a clean and organized approach to the common wires.
Sent from my Nexus 5X using Tapatalk
suckerpunched
I do that quite a bit, but I use but connectors without the plastic cover and a piece of heat shrink tubing over them. I use only the heavy tubing (my vendor calls twin wall) heat it up, it shrinks and glue oozes out and seals it. also good quality crimpers.
JSmall
Your dash looks great! I daisy chained all my switch backs together and it worked great.
crawler73
JSmall- where did you get the wiring diagram for your switching? Did you make it?
crawler73
What program did you use? I like the idea, makes sure things are going where they need to.
crawler73
Yea that would be great! Still trying to wrap my head around all the wiring I have to do.
markw
Jaromy it would be awesome if you'd post that up. It would bee perfect for my '66 project.
Mark
JSmall
I hope you don't mind kiteoregon
This is very crude, but it will help me remember where each color goes after some time passes.
