trailpsycho
- Dec 11, 2003
- 4,856
I have been reading that the Drop track bar bracket can damage the frame as you start to run bigger tires and beat on the truck a bit. I already have a Drop Track bar Bracket installed from my initial lift (2.5"). I am doing a frame off build and installing a 5.5" susp lift (deaver coils and leafs) with Cage long arms and shock mounts. I plan on running 35s or 36s with 4.88 gears (ARB front Detroit rear). Should I ditch the Drop track bar bracket for an axle mounted track bar riser bracket? If I do, should I just cut off the extension along the bottom of the orginal bracket? Seems right. To any of you that have done this, is there still room within to mount the track bar with the two brackets there. I am about to have my frame hot-dip galvanized and coated in industrial grade polyurethane...dont want to have to do frame repairs down the road or foul up the coating by having to grind to re-clearance for the track bar. Am I over thinking this, being paranoid or on the right track? Please give me feedback soon as I have only a window of a couple of hours after I pick-up the frame from the sandblaster before I have to make the out of town road trip to the galvanizer. Yes, pics will follow. Thanks for any feedback and advice.
John
John
