Cutout for twin stick
Kyle.malone
Norman, OK
Next weekend I will be getting my body back onto the frame. I had a T shift original shifter when pulled. I am now going to a J shift twin stick. Has anyone done this or know how big of a hole I need to cut to have the twin sticks fit through without removing them? Or will they have to be removed and reinstalled. Thoughts. Recommendations.
garberz
Bronco Influencer
Conejo Valley, Ca.
I have a 2" BL on mine. So it is very easy to R&R the twin sticks. I just have a small hole on top of the tunnel with no access down the side, the boot covers the hole completely. Obviously the more BL the bigger the cut out will need to be, but I didn't need an access panel.
Mark
airbur
Castle Pines, CO
I have a 1" body lift and was able to simply cut a rectangular hole (about 2"x3") and then fit the panel over the twin sticks. After I got it all together, I ended up having to add a small 1"x1" notch as the right shifter needed a little more room when in the full-back position.
JohnJohn
Richmond
You may not have to cut at all. I have a 2" body lift j shift and did not need to cut. I went with the jb fab twin stick.
Kyle.malone
Kyle.malone
Norman, OK
Sweet. My 1" BL will be here later this week. I might enlarge the hole a little from the T Shift cover just to make sure. Glad I won't have to do any more cutting than that. Thanks for the info!
matt w
here is the hole i cut...;D
..I then bent 1 piece of aluminum to exactly match the tunnel. I only used 2 pop rivets one on top & one on the bottom. A) Because that all it needs to hold it secure if bent perfectly. B) Removing only 2 rivets for a trail fix is a lot faster & easier than removing 15 rivets. C) Less holes to drill into tunnel.
I am still searching for the photo of the completed cover..oh ya I painted it black! ;D
