68 Broncoholic
When I pulled the NP435/D20 out of my 74 I decided to change t-case's (had 2 spares) cause the one that was in there was hard to shift. I found out (after t-case is installed) that the front Yoke on the repalcement D20 has the old 1-7/8" wide bolt pattern Yoke instead like the standard Spicer 1-1/2" I have drivelines for.
No problem, I'll swap yokes from the one I had in there.
I took the Spicer yoke off my old D20 sitting on the ground but couldn't get the old style off the replacement D20. I tried a 4' cheater bar after the impact gun couldn't do it. Then added some heat and pennitrating fluid. Then I tried driving forwards with the bar wedged on the frame and that wouldn't do it. Any other ideas? This nut must be rusted or installed with green or red lock tite.
