D20 Input gear - keep for ZF?
70EB
Gig Harbor
Sawpping from C4/J-shift D20 to ZF/same D20.
I assume I keep this input gear with my transfer case for my ZF install?? This is what the spud shaft connects to?? How do I get it off - some kind of snap ring?
I am selling the C4 and want to make sure of what I am supposed to keep to reuse the transfer case.
Thanks again
Bill
Past_Miner
Yes, you will need to keep the gear. If you remove the snap ring from the shaft the gear should slide right off.
70EB
70EB
Gig Harbor
That's what I thought. Thanks. I need to keep the snap ring too for the ZF stub shaft, correct?
Past_Miner
I don't know if the adapter you are buying will have a new snap ring or not so you probably should keep it. It isn't a particularly special snap ring so you should be able to pick up a replacement at any good parts store. You will need one to hold the gear on the new shaft in the adapter.
