I have dual fuel tanks on my 74. There are no electronic fuel pumps. The PO installed a Dakota VHX gauge but never wired a ground for the fuel sensor. I figured this may be why I am seeing erratic fuel level readings, specifically when the headlights are on.
To confirm this, I jumpered the “FUEL -“ terminal on the Dakota control box directly to the fuel sensor ground on my main tank, which the PO had attached to the chassis. Per Dakota, “FUEL -“ should not be grounded to chassis, only to the fuel sensor ground. With this change, the ohms readings are +/- 8 ohms with the headlights on/off, which is a vast improvement. I think I can live with this and I understand this is fairly normal operation.
However, this got me thinking, what is the proper way to ground the auxiliary tank as well? Can I simply splice the ground wire from “FUEL -“ so it branches to both main and aux tank sensor grounds or would this reintroduce the issue?
