CJ who???
I recently installed a stainless steel twin stick shifter on my J-shift Dana 20 T-case. Everything went pretty smooth as far as installing.
Question is; is there a proper sequence to shift in and out of 4-low and 4-high and back to 2-high ???
The reason I ask is because after I installed it, I checked for proper shifting with the hubs UNLOCKED. Everything was really smooth. When I tried it with the hubs locked on a dirt road, I ran into issues. I some how got the front axle in low-range and was unable to shift the rear axle into low-range, so I had it stuck in both hi and low (NOT GOOD). I couldn't un-lock the front hubs either. Everything was bound up pretty good. After about 10 minutes of working it, I finally got it back into 2-hi without ruining my T-case.
