Ok cool I am a heavy equipment filed mechanic 30 years I have those things. I don't plan on doing heavy wheeling with her and have already
Done the disc conversion to the 30. But I want to go to 411 with the 33s and a six. Don't I need that spreader tool for the 30? Thanks!
I've never actually set up a Dana 30, but I will think it's similar to a Dana 44 or Dana 60.
The carrier bearing preload comes from a "tight" fit of the carrier with bearings and races. After determining the total shim pack thickness, just add .005 or so to achieve the preload. You should be able to install the carrier assy in the housing with a dead blow hammer. To remove the carrier (when all else fails) run a rag in between the pinion and ring gear as you turn the yoke. This will force the carrier out of the housing.
Here's a good article on setting up a Dana differential. The article is on a Dana 60, but the Dana 44 is pretty much identical. I'm just assuming the Dana 30 won't be significantly different.
pirate4x4.com/tech/billavista/Gear_Setup/
Oh, yeah... you'll also need setup bearings for the carrier and a setup race to set the pinion depth. I made my own from the bearings I removed from the original carrier. Just used a Dremel to open up the inside of the bearings (and the outside of the race) so it was a slip fit on the carrier.
Before you remove the carrier bearing caps, make sure they are marked, so they go back in the exact same orientation.
