Dana 44 Front Axle Tube Wall Thickness 1976 Bronco
Swerve
Hello...
Does anyone know the wall thickness of the stock 1976 Bronco Dana 44 front axle tubes? Was there more than one variation? For example a regular duty (thinner wall) and heavy duty (thicker wall)?
Thanks, Swerve
bmc69
All the same. Don't have a number right handy but it's out there.
bax
Old Member
I know their at least .250 why are you wondering?
Swerve
Swerve
Hello Bax,
I thought (hoped?) they were 1/2" thick in '76, or mabe that was '77?.
I am still trying to figure out which route to go with building my front axle. Use / modify / strengthen my '76 axle or have a custom one built. According to SCORE rules I need to use the Dana 44 for the front...
Thanks, Swerve
SHX669
Hmm - not sure of thickness off hand but definitely don't think they're 1/2 " - that's a chunk of heavy metal .
spap
Axle
Thickness/Size
Dana 30
2.500" x 0.250" wall
Dana 35
Dana 44 1/2 ton
3.000" x 0.250" wall
GM 10-bolt
GM 12-bolt
GM 14-bolt
Ford 8.8
3.250" x ?.???" wall
Ford 9-inch
Dana 60 rear
3.125" x 0.313" wall
Dana 44 front 3/4 ton
spap
A 3/4 ton Dana 44 is .500 on an inch. 1/2 ton .250
Just info off of google
Swerve
Swerve
Thanks spap! Good info, I guess I will be calling Currie soon...
Classic 4x4
According the the 1976 Ford Data book, the Dana 44-1F in the Bronco has a 2.75 in. diameter tube, 0.312-in (5/16") wall thickness. It was rated for 3,000-lbs. GAWR. The '71 & '74 Data Books are the same.
The 1/2 and 3/4-ton D44 axles are listed with the same diameter but 0.50-in wall thickness. GAWR was 3300 and 3550 respectively.
Going back to the D30, the '66, '67 & '68 Data Books list it at 2.50-in dia. and 0.312-in wall thickness.
In that same era, the half tons were 2.75-in. but only .375-in. wall (3/8-in.) The D44HD (for the heavier GVW 3/4-tons, optional for the lower rated trucks) was 0.50-in wall.
spap
Yea currie is awesome, they used to be about 10-15 minutes from where I'm at.
