Finally...
OK, I think we figured out that the problem had to do with the Pinion depth...
A little note, the housing came as a bare housing, so there was no initial shim pack to work from for anything, so we had to set pinion depth from scratch.
On top of that, the dial tool we were using, although it cost about $120, was just a joke... it bolted to where one of the end caps is, and had like 2 joints BEFORE the measurement! I mean, we're talking measurements in the thousandths, and there are 3 total possible sources of error??
Anyways, it became clear that we needed to move past this tool...
SO, i called up a buddy that works at a machine shop and had him do a little "overtime" work for me
We came up with a plate that bolts to all 4 holes for the end caps...
I will tell you this... I KNOW the pinion depth is right on ;D and it only took 2 tries...
So tonight was cut a little short b/c my buddy's wife was really pushing for us to close up the "shop" by 10pm, so I only got 1 pattern after we kinda rushed through the carrier setup.
Backlash was .06 (spec we were using was anywhere between .04 and .10)
Looks a little deep, but I think once we torque that pinion nut down to 220 ft-lbs (it's currently at 100) I feel kinda confident about this one... what do you guys think of the pattern (AND the new tool!!!)
PS... Aussie locker came in today
gonna go ahead and put that in too!!!
