- May 24, 2004
- 3,413
I'm tearing down and cleaning up a set of 60's from a '79 F-250 to go under my bronco/buggy build. The disc/rotors and drums are all toast. I want to go with 4 wheel disc, but also would like to run a 15" wheel. I've heard of grinding on the caliper to allow room for the smaller wheel, but also have seen the smaller brackets that allow the 15" wheel. If I use a smaller bracket, what caliber does it use - single or dual piston?
On the rear, I was considering using one of the Dana 60 rear disc brake brackets from ebay that uses 1975 Cheby 3/4 ton Front calibers. I wonder if those will allow room for a 15" wheel?
Thanks for any help/advice.
Robert
Robert
