Dash knob removal
Tulsa76bronco
I am not sure how to remove the headlight, and heater knobs they don't have the Allen screw like the other two how do I get them off. I am taking dash off
RedWings69
on the headlight there is a button on the back of the switch towards the back on top - depress and pull hard if it has been on there a while. The knob comes out with the shaft. The heater knobs (each side of the switch?) do not come off they need to be unscrewed from the back (retaining nut) and the cables disconnected from the heater core and switch under the hood- they come out as an assy. It's been a while since I did it but pretty sure I am on track.
Specracer
If it matters, choke is the same as the heat controls, you have to take the cable and knob as a complete assembly.
Tulsa76bronco
Tulsa76bronco
Jon by cutting them doesn't that leave more of the assembly shaft out more when I put on your own knobs? Does that cause light to stay on some or heater temp etc
