Dating tires
bax
Old Member
I am told that tires have a build date on them. Some kind of code I presume. Dads build had a good set of tires on it when i started. however we are sure they are old. the guy said it had sat for 6 years. the tires look good but I would like to know when they were made. I dont want to run anything that might come apart due to age. dad wants to run them but I say no way. is there a way to tell when a tire was made?
Bax
bax
bax
Old Member
Very good information. thank you very much.
bax
bax
Old Member
Looks like I have a set of 2002 and a set of 1996
Looks like new tires for dad.
stock1970
Olathe, Kansas
guess i should check the date on my tires, i know my dad purchased them in 92,, lol. and i just hit 90mph a few days ago and had pedal left.. woops..
byson1
Nashville
Environmental conditions have more of an effect on tires than anything. Just like a paint job that's sat out in the sun for 20 years vs one that's been inside a garage for the same time period-ultraviolet rays and ozone are the primary things that damage tires. Being an ex Goodyear employee I would not hesitate to, and have run 10-15 year old tires when there was no significant evidence of weather cracking or unusual wear. I always told the customers though-if it makes you feel safer and sleep better at night- then put some new one's on.
rhino2104
I wouldn't worry too much if the tires appear to be in good shape. I ran old tires on my old truck for a long time without an issue. Do a thorough visual inspection on them for any signs of weathering or cracking. If you don't see any then I wouldn't think twice about using the old ones.
jdamach1
Tyler, Texas
I'm sorry guys, but I have to disagree. Even though a tire may "look" good, it still could be bad. Case in point, my '70 Mach 1 is a show car that I drive and do not trailer. It is stored under a car cover in a locked garage. Every time I drive it, I clean it. I restored it 10 years ago and put new BFG TA radials on it. Last summer, I had the left front tire internally collapse on me. I thought the front end had fell out from underneath it. My tire dealer inspected it and said that it collapsed from "old age". The tires were never abused, properly aired up at all times and keep clean. The tires looked brand new with zero cracking or dry rot anywhere.
I prefer to ere on the side of safety. It is not worth hurting someone else, my family or my car for several hundred dollars worth of out dated tires.
screamin reel
Calgary, Alberta, Ca
It's amazing how so many people will spend $30,000, $40,000 plus on their dream vehicle only to cruise around on old unsafe rubber instead of spending $1000 every 5-8 years to keep them and others safe.
It has been well documented that rubber breaks down over time. As others have said, a tire can look 100% but in reality it is a ticking time bomb.
Some insurance carriers will not cover an accident if the tires are over 10 years old. Hidden in the fine print.
Almost all of the European tire manufacturers state an expiry date for their tires. Mandated by the government. For some reason North American politicians don't seem to think it is a big deal.
chuck
Ingram, Texas
The co. I used to work for checked into tires after having some trouble and after a lot of study decided to discard all tires at 7 years, even if they were never mounted and spent the whole 7 years in a warehouse. Seems tires have lube/preservative made into the rubber that comes out as they are rolling so if they are not being used like on stationary equipment or in a warehouse they go bad.
byson1
Nashville
The dating comments are more interesting than this tire tech stuff but...UV rays do effect tires. Tires are manufactured with carbon black to offset this but just like sunscreen-it's only so effective. Take 2 new tires, set one outside for 10 years and another in a climate controlled warehouse and I promise you'll see a difference. Not realy arguing what's been said but there's more to it than just the date. Then again, maybe I have a death wish for continuing to ride on my Goodriches that I bought back in 2000 and are only half worn out and get parked in the garage 90% of ther time-but they sure are pretty;D
