Do I need a solenoid
jimmymac
Battery is good. I turn the key and it it just a fast vibrating like clicking noise. Won't try to turn over.
Skuzzlebutt
PhD, Dr. of Broncology
Honeymoon Bay
Most likely, you need new battery cables. The rapid clicking (buzzing) is what a good solenoid does when there isn't quite enough power getting to it. The clicking will slow down as the battery weakens
Cables can look fine but still have corrosion building up inside the insulation.
Have you had the battery load tested? Merely checking a battery's voltage is a useless test that can mislead a diagnosis.
Mark
Bronco Klutz
NW Indiana
There's been a few times I've sworn a battery is good only to replace it and solve the problem
J
jimmymac
Cables look new .I replaced them about a year ago. Could it be where the Bat cable grounds to the block ? maybe dirty ? Battery came out of my other truck it was ok. If not any other ideas.
J
jimmymac
If I jump it and it starts does that guarantee it's the bat.And does it matter how many cranking amps the bat has. I know there is a min but can you have too many?
J
jimmymac
Well guys I went down to Auto Zone to check my battery but they said it had to be charged and retested. I didn't want to wait so I bought a new battery and the bronco fired right up. Thanks for yall's help. Again.
