Door glass removal and installation??
72moore
Re
beyer05 said:
What is the best way to get my door glass out of my door and into a new door?
I don't know how specific this is, but
take door pnl off ,believe there are a couple screws holding glass.
Shouldn't be too difficult.
big daddy walt
Barnegat
I changed mine recently and it wasn't that easy. I used the window and the piece the window attaches to from the donor. I took off the inside door panel.(window crank and handle) and unhooked the clip that holds the sliding bushing at the bottom of the window.
I had to unbolt my wing window and remove to get the glass out . you may have to remove the window seals at the opening where the glass slides in also.
Reinstall the opposite way.
or you could just replace the glass. there is an article in the tech section.
B
beyer05
Tulsa, Oklahoma
I got it. Had to remove all of the tracks to get the main window to slide back enough to get the wing window out. Then I lifted out the main window.
