g8rb8t
- Feb 23, 2008
- 1,476
My passenger door rod connecting from to the outside door knob is no longer attached.
I've got the rod with the threaded metal nut on the end and a small "pin" and what appears to be a metal clip (washer attached and goes around the pin). I also bought some of the latch rod clips from JBG to reconnect them.
Is the plastic clip supposed to be used on the end of that rod? I can't really tell how it attaches and stays in the door latch hole.
Also, it appears the pin is supposed to go through the hole and point towards the back of the door (latch side) vs hinge side. Can anyone confirm that?
THanks!
THanks!
