So after making the mistake of taking the Bronco in to a local body shop to have the pass. side door post replaced, I'm now on to cleaning up the mess and possibly doing it myself. I should've not bothered with the body shop since they hadn't done one before, but I figured they'd do a better job than I would...not so sure anymore.
I thought we had an understanding that to remove the old one, they would drill/cut out the spot welds and cleanly remove it to maintain the integrity of surrounding metal. I even did some prep work before taking it in by stripping/removing all paint/primer at all junctions of the door post to the body. Well....they cut the old one out with a torch....Yikes! That bugged me, but I was ok as long as the finished product turned out acceptable. When I went to pick the Bronco up when it was "done" I was disappointed. They did install the new post, but, in the wrong spot...too far back by about 3/16". That left a wide open gap between the windshield and door frame. At that point, the shop manager said they would re-do it and would very carefully remove the new door post so it could be moved into the correct position. When I went to check on the progress after a few days, believe it or not, the guy cut the new one out with a torch also!?!?!? WTF? The shop has compensated me for a door post, but the Bronco came home with me to try to pick up the pieces and make this right. I have another new door post and I've started the process.
My first question is in pic 1, does the lower flange of the door post slip inside or behind the flange of the outer rocker? I suspect it does as that is how I remember the stock one being.
Second question is whether the flange slips in between the rocker and the inner kick panel? Same there...I think it does but I'm looking for confirmation.
Last question is about what is left of my rocker after they hacked TWO door posts off the Bronco. Is what's showing in pic 3, enough of the rocker to even attach to the door post?
The additional pics are how the new post looked after removal, & a comparison shot between drivers side post location(yellow) & passenger side post location(primer)
