- Oct 8, 2019
- 548
This is my weekly question/plea for help
The top seam above window on my drivers door is broken, and as you can see someone did a shoddy repair at some point.
I’ve cleaned it up and used a file to get edges straightened out
And used a ratchet strap to pull it together and cleaned it some more
I’m a novice welder and have some questions.
Does this look ready to weld or shoul I sand it smoother?
I’m using a Lincoln 180 mig with .23 wire, any suggestions on the settings? I’m thinking lowest voltage (A) and medium (4-5) wire speed but don’t want to burn through.
This will not necessarily be a permanent repair as the truck is eventually going to Tom at Lick Creek for all of the body work. I just don’t want to drive it around with the seam apart.
So should I just throw a couple tacks on it?
Clean up the outside and tack that too?
