nickmyron
As some of you may know I am building a 351W....
The original 351 heads that were on the block were cracked so i needed to get a new set. I was informed that 302 heads are the same as long as you get the same cumbustion chamber size, and all you need to do is drill the bolt holes out to 1/2"
Well I got a set of 302 heads and i drilled the bolt holes out to 1/2" a while ago, but it wasnt until yesterday that i was able to try them on the block....
And what i found was that it is very hard to tighen the bolts down. So i took a dial caliper and measured the diameter of the old heads....I found that they are 30/100's bigger then the ones i drilled. So that is why it is so hard to tighten them down because the hole & the bolt are the same size (1/2").
I still had the old cracked heads, so i put them on the block to test how hard the bolts were to thread in and they are much easier, while the new drilled heads are very hard (but still not impossible)
So my question is do i need to drill them a little bigger to allow for expansion or is it fine?
Thanks,
Nick~
Thanks,
Nick~
