sellitall
I truly believe that the reason PPG bought ICI, BASF bought Glasurit, and Dupont bought Spies and Standox was to get their European waterbourne technology. I've been hearing since the late 90's "we are going to have to switch to water, it's the end of the world! We don't want to change!" The EPA has gotten more and more strict on the VOC's and the paint companies have got the VOC's down as far as they are going to get them. After spraying Spies waterbourne this week it puts any paint I've used to shame! I've sprayed PPG, Dupont, Standox, Sherwin-Williams, Spies, and some ICI full time in my career. Waterbourne paint is what urethane did to enamel![]()
I've demo'd three waterbourne paint lines. BASF 90-Line, Spies Hi-TEC, and first generation Standox water. The Spies took 1 1/2 coats of base and dried quick. Here's a video demo of the blend process. Starting at about 2:00 he applies a wet bed or 1K clear. Then 1 1/2 coats wet on wet with no flash off and then does his blends into the adjacent panels. Wait 10 minutes and then 1 1/2 coats of clear.
That is the cleanest paint booth in the freekin' world!! They must only employ OCD employees. I'd be let go the first day.
What's the deal with that limp wrist technique? I have always been told to keep my wrist straight to avoid uneven panel coverage. He must have perfect muscle memory. Also, like the OP said, he really laid it down thick on the first coat. What's the reason for that? I was always told to fog on the first coat.
Urethane actually replaced lacquer paint in most of the shops around my area. Most decent shops did two stage systems as well, but with lacquer base and clear. Most lacquer paints are illegal now, but they produce some of the best paintjobs to dat. The problem is they are a "soft" paint prone to chipping. The advantage is you could pile the clear on and rub it with 600 wet. It was literally like looking in a mirror if done right. My dad used to come home with his fingertips raw as hell from wet sanding.
Oh yeah, I see some "holidays" in the tape job.
