duraspark ignition upgrade - TFI coil plug wiring?
saxman
Austin, TX
I am just about to finish my duraspark ignition upgrade.
http://users3.ev1.net/~bmarr/duraspark_ignition_upgrade.htm
I already had the control module, but I did replace the dizzy's springs with the lighter ones so it would reach the vacuum advance sooner. I am about to put my TFI coil in, and I just bought the new coil plug for the coil because the stock "C" clamp does not fit. How do the new wires on this plug connect to the wiring system?
Here is a pic of the plug. It has three wires, 2 greens and a red.
thanks for the input...
Cooter_76
Scott,
I would imagine that the Red wire will splice into the wire that is currently connected to the "+" side of the c-clip for your old coil and one of the green wires splices into the "-" side. The other green wire probably goes to your tach? Do both green wires go to the same terminal inside the plug?
saxman
saxman
Austin, TX
yea, that was the conclusion that I came too. both green wires go into the same terminal.
