I ordered and received my new Dutchman axles. Based off the stock setup but made some tweaks including smaller flange for my brakes, screw in studs, set 20 bearings and 31 spline.
Their set 20 bearings aren’t the norm. They’ve created a different retainer that allows you to use an inner seal (their own, not stock) and their bearings are packed with high temp wheel grease and do not need the gear oil and also sealed on the outside like regular set 20 bearings.
Just curious if anyone has used these and experience. I do plan on trying it this way but. If I ever decide I don’t like it, I can just remove the inner seal.
I found some write ups that say they’ve done this to eliminate leaking in the set 20 bearing setup.
