    Discuss it more here:
  • The Classifieds forum is a place to buy and sell, not an open forum for people to give their opinions on Bronco values. Unless the seller specifically asks for help on pricing, please don't critique quality or asking price. If you're not interested then move on.
    Thanks!
Early Bronco Narrowed High Pinion Dana 44
Status
Not open for further replies.
mxer
Gallipolis, OH
I Have A High Pinion Dana 44 In A Early Bronco For Sale. This Came Out Of A 78 0r 79 F150 Or Bronco And It Has Been Narrowed To Fit A Early Bronco It Has Disk Brakes And Steering Any Other Frontend Parts You May Need. This Has The Larger Axles That A Factory Eb Dana 44 It Was Narrowed By Cutting A Section Out Of The Center Of The Passanger Axle Tube And Welding Together Looks Like They Did A Good Job. Not Sure About Gear Raito. It Is In A Rolling Frame Been Setting Awhile Proably Needs Gone Thru. 500 Dollars Will Sell Rear End Or Other Parts You May Need 740-446-1327 Or 740-578-1078
thegreatjustino
Red Head Grease Monkey
Stockton, CA
Are you saying the center of the tube was cut, shortened, then butt welded back together? If so, that is the redneck way of shortening a full size axle and shows that it was not done by a competent shop.
cougarmandan
Bonanza, AR
Are you willing to ship. Can you post or send some pics. My email is cougarmandan
@hotmail.com if you want to send them direct. Thanks, Daniel
mxer
mxer
Gallipolis, OH
As far as the way this axle was shortned, i don't see this causing any problems as long it was alligned properly. This axle was ran for a good while with 38s no problems other than broken axles(due to 38s and v8). I belive this was shortned this way to keep from having to cut and reweld axle wedges when moving inner c inward. I dought this was done by any shop more likely a individual. Stength wise i don't see it failing a good but weld is pretty strong if done right and if you don't trust it there is plenty of room for reinforcement around axle tube.
Status
