z-one311
I have 3 3 speed trans out of 2 70's and a 71. @ transfercases out of the same. Bell housings. I have two hort block 302 engines. One is out of a 70 and has been bored .40 over. All it is is the crank, rods, pistons and block with oil pan. They are wore out but still salvageable. Do have a set or two of heads also. Sold one of my Zf's to nyles but have axcess two a couple more. I have one posi center chunk for a 9 inch rearend with 31 spline. Have 3 205 transfercases which is said to be the strongest and best one ever made. And for your information will bolt directly up to the ZF and if you want to use stock shifter. You will have to knotch a U shape out of the back of the trans. I have 2 dana 30 front ends both are 4.11 gears. I have one complete dana 44 frontend with 3.54 gears and one dana 44 housing with no gears or knuckles. I do also have two sets of knuckle out disc brake set-ups for them. That is calipers, knuckles brake lines if you want but i would buy new. And discs if you want but once again i would go new. And all nessecary hardware. Stock hubs included. You will need to buy your own steering adapter from bc broncos. To use your stock steering tie rods. If your looking for other parts please ask. One complete spare tire set-up and one swing arm and side mounts. Also 3 speed floor shifters. One hurst and one duff. The duff is complete and the hurst needs a shift arm that you can get from toms bronco for 30.
3 speed trans 150
transfercase 200
engine short block 150
steering box 4x4x2 450
stock p/s box 350
zf trans 650
205 transfercase 250
dana 30 200
dana 44 550 with disc brake set-up 800 installed
dana 44 housing 250
disc brake set-up 250
spare tire carrier 150
swing arm 75
3 speed floor shifter hurst 150
3 speed floor shifter duff 225 complete
3 edlebrock carbs 600 4 barrels 125 off running motors work great 379 new
1 upper/lower Fuel injection intakes with fi harness 150. Includes injectors and all of the stock components off a ho mustang motor. Its the passenger side intake. Not the driver side. Has the 19 lb injectors and i might have the harness but not certain.
3 speed trans 150
transfercase 200
stock p/s box 350
zf trans 650
dana 30 200
dana 44 housing 250
swing arm 75
