If you look at the pictures on my bumper thread, you can see how the brackets are mounted into the frame horns. Very beefy brackets are used on this bumper.The lines are very smooth, the brackets are bolted into the horns of the frame with four bolts each bracket, the bumper uses 14 bolts in total, there is no need to drill any new holes, the brackets allows you to raise or lower the bumper. The bumper weights about 75 lbs. I'll be installing a warn winch very soonyeah, I like that bumper alot, plan to get one for my next Bronco. How did you like the construction of it? pretty solid?
The rear is almost ready.
The lines look good, is there any way you can make the bracket both lower and closer to the center of the car? In my application, I don't have the room to hang over off the side without catching trees.
tail light looks blocked as is
Yeah, get the tire further towards the middle like the stock carrier and a little lower and I would put my money on it.
