Pull the top off pull out the metering rods and the jets and clean them out. It's probably just gummed up with gas deposits. Clean out the bowls and try again. I'd also suggest blowing out the fuel lines from the fuel pump back, new fuel filter and clean out the gas tank. At least slosh the bad stuff around and dump it out, then put new gas in. Should run much better...
