Chicago71Bronco
Hello
Looking for a little help here. It started with a leaky 2150 Motorcraft carb. In true Bronco fashion, rather than order the $25 rebuild kit I figured why the hell not upgrade to a 4 bbl and spend more money while I'm a it.
I'm looking at purchasing the Edelbrock Performer intake, performer 600 CFM carb, air filter combo from Summit - http://m.summitracing.com/parts/cmb-03-0126
I'm currently running the stock 302 and stock air filter with a 1" body lift. If the air filter in the kit is 2" will this fit under my hood? I also asked about using a drop base air cleaner but the guys at summit said that it's not an option with this carb because of the linkage.
So has anyone else tried this or know if this will work?
Here's the current setup...and yes thats a shop towel under the carb
