browngr5
I just finished my 1990 5.0 EFI conversion.
My fuel pump runs when I turn the key on but it doesn't shut off after 2 seconds like I expected.
It will start and run but I need to re-tune the chip from 30lb injectors to 24lb injectors. Its super rich right now.
Ron Francis Bronco EFI /mas air harness
24lb injectors
80mm throttle body
75mm mass air
Trick Flow 360hp twisted wedge top end kit
Sherman Tank w/ pump in tank
1- double checked the ground wire at the back of the intake.
2- switched to another A9P computer.
3- checked 12v ignition wire at firewall
4- checked keyed 12v
5- checked 12 battery connection
Is this normal and can I alter the wires to make it shut off after prime?
24lb injectors
80mm throttle body
75mm mass air
