EGR gasket question
73 Bronco Exp
Does anyone have a part number for the gasket that goes in between the egr spacer and intake manifold on a stock 73 302 2 bbl? Looked online for hours and called local auto parts stores with no luck. Thanks!
br0nc0xrapt0r
Loves pickles
I just got some gasket paper from the parts store and cut one out for my EGR block off plate.
73 Bronco Exp
I might end doing the same. Unfortunately the old one shredded when I pulled the spacer off and I have no template. Do not want to block passages as that was the original problem. Thanks.
br0nc0xrapt0r
Loves pickles
just coat the mating surfaces with a thin coat of grease then press them to paper, the pattern will give you a template. Did it for a water neck for a generator out in BFE Afganistan.
