t.lay
ok, was trying to run down wiper issues - discovered there was no power to the switch (orange wire). Ran a jumper off the ignition switch to the red wire on the wiper motor - all worked fine. So when I started tracing back the orange wire on the wiper switch I discovered there was no power at the fuse panel for the bottom section (wiper/radio, turn signals, heater). Now what??? Fuse panel is broken down into 3 sections - red (battery) constant - also has a gray fused link wire attached, white (ignition powered section) and black. Basically, the black section isn't getting power. Any ideas where the power source is or where the next place to look for faults? (1st pic - no power to upper left section - connected to black wire on center lugs - 3rd pic - bottom left 4 junctions - no power ignition on or off. No label on black wire - at least that I can read.
