UPDATE 5/15/08. Most of this is gone. I have a more recent post with this and some other stuff.
- seats: fr. buckets; 2-tone black/gray vinyl; minor wear (one piece if the piping on the driver is torn); this one is local only. I may have to keep the passenger brackets (won't know until the replacements come in. Will consider trade for a fold and tumble rear seat. Will consider selling the entire set of fr/rear seats
- GONE - chrome door mirrors
- set of 15x9 alloy rims; old school swirl design with 3 painted black inner cutouts; I belive they are Progressive; one of them has been curbed (repairable if desired). Good extra set for winter or special tires, etc. I have them in boxes, but shipping may be cost prohibitive)
- GONE - heater vent box/passenger side fresh air
- GONE - stock hood prop rod
- GONE - stock overflow tank hold downs. the tank fell to pieces but the metal hold downs have been painted black and are in good shape. this is for the tank location on passenger fender well
- GONE - metal hood
- GONE - stock black plastic door cups
- GONE - stock door hinges, straps and hangers
- GONE -stock heater box
- dr cowl vent/fresh air unit - make offer if you really want it, otherwise I may "customize" into a storage box
Will part out a perfectly good 302 after 4/10/08. I won't want to keep anything but the short block and timing cover. Make offer for what you want. You can make offers for:
- GONE - Motorcraft 2bbl carb
- 3 groove/3 bolt crank pulley for 302
- alt brackets for 302
- PENDING iron heads
- GONE - exhst manifolds
- GONE - Motorcraft 2bbl intake
- GONE - cast iron water pump (regular/v-belt rotation)
- GONE - distributor
- coil
- coil bracket
- no flywheel, no PS pump bracket, no dual hump oil pan
Misc tow rig junk:
- K&N panel filter for '97-0x Ford Powerstroke
- 2001 Powerstroke stock air filter box
- Behind seat tool tray for 2001 F250 crew cab
- 1997-200x Superduty passenger side "Excursion panel" sound insulation panel for firewall
- GONE - metal hood
- coil
- coil bracket
Misc tow rig junk:
