377
I'm getting ready to prime my roll cage in my current project and had some questions. I have been reading through some posts and am kinda confused should I etch prime the roll bar or just use epoxy primer. After spraying either of those should I use a primer sealer then final paint? While I'm here I have another question I also need to paint the interior of my fiberglass tub it is gel coated. Do I just sand the tub to help adhesion and then spray with a primer sealer. What grit paper should I use? I have never painted fiberglass so I figured I'd ask here because I've Lways gotten great help here. Thank you in advance for your help.
