Exhaust Manifold Bolts
jeremywatco
San Diego, CA
Quick question...
Striking out at all my local auto parts stores for new exhaust manifold bolts. Can I just pick some up at my local hardware store?
Mine came out just fine however they are looking preeeeeetty sketchy. Dont trust them to reuse them.
J
jeremywatco
San Diego, CA
your auto parts place should be able to order these.
https://www.dormanproducts.com/p-633-03099.aspx?year=1974&make=Ford&origin=keyword
https://www.summitracing.com/parts/rnb-03099/overview/make/ford
https://www.summitracing.com/parts/rnb-03407/applications/make/ford?prefilter=1
Remember you have 2 exhaust manifolds so you need enough sets to cover on both sides. assuming you are using the stock manifolds.
Thanks. I have those. I am referring to the bolts that hold the manifold to the head. There is 8 of them. 4 short, 4 long. I snapped a stud on the flange and had to remove the manifold in order to get it out. I have the bolts so I can match them up, just wondering if they need to be special "exhaust bolts" or if normal grade 5 from the hardware store will work.
ENDLIFE
I used plain old grade 5 bolts with a flat, and a lock washer. Worked out beautifully, and still hasn't come loose.
PickleJar
I used regular 3/8 USS grade 8 bolts, with SAE flat washers from the hardware store. Just took them in to match up length. The 4 studs I took to a local mom and pop parts store and they pulled a bin of mixed stuff out and found them new shiny and everything.
Steve83
Neither Grade 5 nor Grade 8 is suited to that application. Grade 7 is heat-resistant, and you'll never find them at a hardware store. Read this caption & shop your local parts stores, online parts stores, Amazon, & eBay:
(phone app link)
If you need a short one with stud head, cut a long one.
904Bronco
San Martin, CA
(phone app link)
You learn something new every day... Grade 7, guess I missed that conversation in shop class way back when. :p Or more likely forgot it...
