fablife
- Oct 15, 2002
- 289
after a crap load of changing, modifying and reading.. weird how some people have great results and some of us have the hard, whining steering. this last build was a super sweet one, so I refused to let it go without a cure, lol
so, it seems the feed is the issue. so here's the easy fix
the return needs to be plumbed into the feed line somewhere between the reservoir and the pump inlet. This can be done with hose barb fittings or drilled and tapped like I did.
it takes a little longer to purge the air out of the system because it's getting recirculated back into the pump, but it definitely works. hope this saves some misery!! JD
