John Griswold
With the used set of 5.5" springs (coils and leafs) i bought the rear of the bronco is 3" higher than the back. From what I'v been told the ride height of the coils is correct in the front at about 12" between axle and frame so the back must be too high. I was looking into Full size Bronco or F-150 coils with more than 5.5" to level the truck. The diameter of the full size/F-150 springs is slightly larger than classic bronco springs. Has anyone put full size/F-150 springs in their bronco? With a little grinding, drilling, and welding I could mount Full size/F150 top and bottom buckets and try taller springs in the front to level the truck. Anyone have any experience with this or advice? Thanks!
