BOSS3024ME
OK so I got to the brake booster and put it all back together it bolts up rod reaches brake pedal.....master cylinder fits.....(This is starting to scare me )<br><br>Question 1. Not much space between the booster and the inner fender well is this correct??<br><br>Question 2. Is there anything to adjust ??<br><br>I didn't look real close but it apears all the rods (from brake pedal to bellcrank and from bellcrank to booster and from M/C to booster) have no adjustability is this correct??<br><br>Question 3. Vaccuum line from booster to?? (I am assuming base plate on carb if this is the case where do you put PVC line??)<br><br>Anyway it looks good and fits nice so one step closer.....who would think that Ford would set this baby up as a bolt on in 1967??<br><br>Thanks<br><br>Paul
