- Jul 4, 2016
- 779
I'm up for some brainstorming and advice. My '74 Bronco finally runs and drives after 8 yrs of solid effort. I'll post a bunch of pics. But my problem is Rt door fitment. It was real nice before paint.
Lt side is great, Rt side is tough. Big gap at bottom of door, mostly parallel with door, I can live with gap, but it should probably come down. B pillar gap is fairly good, it gets tight in lower 3rd but I'm happy with it. The A pillar gap is hitting at top of door, and tight at top of fender to above upper door hinge.
There are two thick shims under passenger floor pan body mount. No shim under body behind passenger seat.
I just loosened up right fender, pounded really hard to get it to move forward, then hung myself and son to pull it down, then tightened up Phillips crews. I actually bent the top of fender more in the top crease when pounding with rag covered wood block. Fender is now against the A pillar, will not move down or forward anymore.
My Bronco was in really bad shape, had to have new A pillars, (RUST), new floor pans, & new side skirts. The rockers were taken off and put back on, all whole new front sheet metal placed from front clip forward of the firewall due to previous wreck hitting in 1.5-2" on either side.
I have an Imron single stage paint job, and if I have to can trim door edge and repaint, . Or do I add more shims? I tried shims on the passenger floor pan, no real difference, but I didn't loosen the other Rt side body mounts. Hmm. I think if I put a shim behind passenger seat it would open the B pillar gap, making things worse, right? The gap is tight at upper part of door window frame and windshield frame.
I have not shimmed the door hinges and would like to not have to. I guess it's time to buy the all-thread and put it in the door hinge holes, realign and lower hinges on A pillar and lower the door a bit. But it won't help fender / door gap. Arg.
Any other ideas how to open up the top of door fender gap??
Forrest in Rescue, Ca
But moving to Sparta, TN in a year.
Sent from my SM-G955U using Tapatalk
