Illinois73
- Aug 3, 2011
- 93
Hello everyone. Im new to the community and wanted to introduce myself and ask for some help with the cooling system on my first EB.After owning 78/79 broncos and pick ups for the last 16 yrs i finally got a EB i always wanted. Bought my 73 from arkansas about 5 yrs ago. All orig. pretty clean and just worn out. Put it in storage for 3.5 yrs while i finished other projects. 18 months ago i finally pulled it out just to get to know it and tinker with it. well u guys know how that goes. replaced 302 with FI 5.0, rebuilt c4 ,fuel system, axles, wiring,suspension and cooling system. Finally got it up and running and after a few short idiling sessions checking fluids and what not i let it run a bit longer and temp started to rise and hit 230. let it cool and it did it again. thought maybe t-stat was bad out of box so i replaced it with 192 from ford. Still did same thing. Its got flow cooler pump, ron davis radiator, stock type shroud and bcb 17in. narrow blade fan. motor is has stock internals and stock pulleys. used infared gun and shot water neck and cylinder heads and gauge seemed pretty close. inlet to rad is reading 100 degrees hotter than leaving side. Its like im not getting flow. Ran it with cap off and didnt see much flow when t-stat opened. Its killing me not to drive it after all this time. Any help would be appreciated. thanks
