1buckeyefan1
- Sep 21, 2017
- 630
So I'm getting to the point of re-fitting my doors and the body lines + initial gaps aren't bad..except for where the window frames meet the windshield. For some reason the passenger is in and the driver side is out. These are different, oem doors that came off another bronco. I checked the body bushings underneath the floor pans and they're both right at 3" (2" BL + bushing)
I've messed around with shims, loosening the passenger side body bolts, and jacking it up, etc.
If it were just one side, I'd be convinced the door frame is simply bent and id bend it back. But since it's both sides, I'm guessing the body didn't go back on straight? But the doors match the panels pretty well.
Anyone been here? I don't want to bend the frames to match the windshield unless it's the right thing to do.
For reference, the a & b pillars are original, as is the windshield hinge.
