- Apr 23, 2013
- 618
I have my entire back floor taken out and I am about to put the new floor and cross bar in but I don't know what the measurement needs to be from the back support to the bar that connects to the wheel wells. If I remember right that cross bar is welded to the wheel wells, is this correct? Should I weld that to the wheel wells first before I put the floor in or weld the brace underneath first on the ground then put the whole thing in and weld to wheel wells after it is sitting there. Not sure would which way would be easier.
Also is the rear measurement between the sides at the tail gate 65 inches, I found the L bracket at the bottom is not welded and just floating so I want to make sure I don't weld it down without this measurement so my tailgate will be right.
Thanks for the help
Thanks for the help
