kiteoregon
- Nov 21, 2011
- 292
So i was reading up on the floor pan replacement here on the forums. I notice lots of people also address body bushings at the same time, so i am guessing it's because once the floor is out, it's "easier" to get to a couple of the mounts? Should i do this at the same time, what else should i be doing while i have the floor out?
I was thinking i would clean up the cross member supports if they are not shot (will check before removing pan), i was thinking i would clean and use a bit of the good ol POR 15 on the cross members. Thoughts?
What else do i need to fix while pans are out, obviously fuel line / break line when i cut them in half, anything else?
Eric.
Eric.
