Froggy77
I am finally to the point of having ripped out all the old crappy metal and have been carefully grinding, cleaning all areas where I will be welding in new panels (drivers floorpan, kickpanel and innerfender, cowl). I have some questions that may be obvious to others, but hey, this is a first for me and I wanna do it right. SO.......
1. I have cleaned and grinded away all the old rust and paint from any areas where I will be welding new metal. I have been putting POR 15 into the floor support channel (great news...it was in perfect shape!!!), the cowl support channel (rusty) and the inner rocker panel. I used the POR Metal Ready to prep these areas and was planning on using weld-through primer on the places where the new metal panels will be welded. I also used the metal ready on these areas to prep them. Is this ok? Should I still spray the weld-through primer over the Metal Prepped areas? Should I grind off the Metal Prep and just primer or just weld to the bare metal? (I have not put POR 15 on any areas where I will be welding)
2. Do I need to grind the opposite side of any areas to bare metal where I am welding (fender lip, etc)?
Thanks in advance. Can't wait to get this side done so I can have more fun on the passenger side!!!
