    Discuss it more here:
  • The Classifieds forum is a place to buy and sell, not an open forum for people to give their opinions on Bronco values. Unless the seller specifically asks for help on pricing, please don't critique quality or asking price. If you're not interested then move on.
    Thanks!
WI Ford 351W Windsor Downdraft EFI Stack Intake Manifold System
Status
Not open for further replies.
rcmbronc
Tomah WI
351W EFI individual throttle body intake manifold system. Purchased new from Pro Comp. Decided to go another route. Brand new never mounted. Includes manifold, eight throttle bodies, throttle linkage, Air horns, fuel rails and fittings.
Asking $595 shipped. rcmbronc@gmail.com
Crush
Greenbottom, WV
what else is required to install this beast and have it running. such as wiring/injectors/sensors/reccommended fuel supply/pcm/etc....and how tall is it from the bolt surface of the manifold to the top of the stacks,,,and what brand
rcmbronc
rcmbronc
Tomah WI
It is from Speedmaster which I think is the old Pro Form.
It is about 11" from the bottom to the top of the air horn. It will need a fuel management system like from Holley or FAST. Also needs wiring harness and injectors. It will need a TPS. Typical EFI fuel system with a regulater mounted on the fuel rails and return line.
I was going to run it with the Ford Mass Flo system and build an air box for the inlet and then run the mass air flo sensor in front of the air box.
Crush
Greenbottom, WV
so really you have to buid an airbox that sits on top of the stacks to be able to some kind of MAF or speed density system on it to make the fi work well. kind of defeats the purpose of having that beautiful intake on there. but I love it.
also if i had all the ford stuff it will run off that, correct?
rcmbronc
rcmbronc
Tomah WI
Yes it will run on the Ford stuff. Would not need the air box for SD.
Status
