- Dec 5, 2021
- 56
I am trying to install the horsepower auto sales ford 9" disk brake conversion.
I can't get the calipers with brake pads installed to fit over the rotors. The instructions said that the piston might need to be retracted in order for them to fit.
I removed the spring, the ~17mm nut, the e-brake lever, the rubber and nylon washers, rotated the integrated hex nut counter clockwise and was able to push the piston further in using force. It didn't automatically retract when the integrated hex nut was turned, I had to push it. This was the result, the piston was flush with the housing.
By the time I replace the washers, lever, and tighten the nut, the piston has rebounded to the point it was at when it came out of the box.
At this level, the caliper with pads installed will not fit over the rotor. If I don't replace the washers, lever, and nut, I am able to BARELY fit the caliper and pads over the rotor. Should I just install it over the rotor that way and then replace all the listed hardware? My concern about that is that the e-brake lever might not be clocked nicely one the integrated hex nut of the piston to position it against the stop it has on the caliper housing.
Does anyone have any advise for me? even with the piston retracted as much as possible without the e-brake spring lever installed, the pads still rub on the rotor when in place...is that normal?
Thanks, I'm stuck.
Thanks, I'm stuck.
