DJs74
- Apr 1, 2014
- 1,135
Has anyone experienced a crack / split in the 9" case at the rear pinon support bearing?
If yes, what was your fix... new case or weld up the split or something else?
I'm there. The case has crack right between the tail of the pinion and the ring gear. Looks like there has been some grinding done at some point on this case for ring gear clearance reasons maybe so it might've weakened it.
I have gone ahead and put a spot of weld on it and the bearing goes in fine - I was a little hesitant because I wasn't sure if the roundness would be distorted by the heat and maybe the bearing wouldn't go in, but it did and seems OK
I've not reinstalled the center section yet - just wondering if others have experienced this and if it is an eventual catastrophic failure waiting to happen or if the other two bearings plus welding up the case will be good enough.
This is not a street vehicle - its the racer... so if any vibration or heat causes problems based on highway use or long runs, that won't apply. However, I am launching on a transbrake so the driveline is getting a lot of abuse initially and for about 4.5 seconds at a time.
I'm trying to understand how the two tapered bearings toward the yoke allow any linear movement of the pinion. If the proper torque is reached and the bearings are properly seated, how does the end of the pinion have any movement that could cause the case to split - or does something else I'm not understanding cause this?
I can't really say what version this case is (I'm not too familiar with them). It is a Ford case, it has Ø3.062" carrier bearings, it has no drain plug in the side, the pinion support has an eyebrow above the yoke - if any of that is useful information.
See attached photo
Thanks in advance.
DJs74
See attached photo
Thanks in advance.
DJs74
