I did my GM brake conversion about 24 years ago before it was popular to go that route. There was this article in Off Road magazine (when they still did real off road articles) about a guy in Englewood Colorado (Alan Dunn of High Country Performance) and his really trick '67 Bronco, Crazy Horse. It had a home built full float axle and a GM disc brake swap so, I called him for info and did my disc swap. Anyway, I bought a Blazer K5 D44 for a $180 and took the spindles and calipers......(wish I would have known about the shafts back then) and sold the rest for $100 because, it was a lot easier and (as you see) cheaper;D than using the Ford parts. Now days you'd be hard pressed to find any solid axle 1/2 ton Ford trucks and/or '78/'79 Broncos in the wrecking yards but loads of Chevys. Go to the yards and pick up a K5 or K10 axle for $150 and you'll end up with all the parts you need (except hubs and rotors) for the brake swap.....spindles, calipers/brackets, brake hoses and a set of axles (you'll have to have them cut down) that'll give you the stronger u-joints and allow you to run the outer snap ring on the Warn hubs (if you're running those) or retain you stock Spicers. It's such a simple conversion, why pay so much for a kit when all those parts are just waiting to be picked%)......just my 2 cents-----------Hans
