frame repaint ??
craigs67
Juneau Alaska
I painted my frame last year and have decided that the color is wrong, I painted it with zolotone and a very good clear. So can I get by with just scuffing the clear coat and shoot or do I have to go farther past the clear.
Thanks craig
allenfahey
I'm guessing you are useing a basecoat again for the color change? If so I would use 400 by hand and follow that with a red Scotchbrite. No need to sand off the clear but if you do sand thru don't worry about it.
At work I use hookit sand paper which is a velcro type backing. When sanding by hand it sticks very well to the scuff pad and then turn it over and use the scuff pad side. By using the scuff pad as a backing pad for the sandpaper it conforms good into the hard to reach areas.
craigs67
craigs67
Juneau Alaska
Sorry for late reply fish are in, I will do that I just got the front diff off agian and will do the rear tommorow. Should I reprime it our just reshoot...
Thanka Craig
allenfahey
no need for any primer unless large area of bare metal. If the spot is very small a spray can of 1K will be fine.
craigs67
craigs67
Juneau Alaska
another question
I had painted my front and rear diffs with por over time they have dulled can I scuff them also and paint over the por, also what is 1k?
