Jmjuhl
Newbie
Finally have my 74 down to the frame and did the oven cleaner/pressure washer treatment last weekend. Next up is a good media blast.
I have a punch list of items that I need to repair on the frame and don’t have a welder, and due to space constraints I’m not going to get one. List of what needs to be done:
Second, does anybody know a good shop in SE Texas, or within a 250 mile radius of Houston, that knows Bronco’s, and can help?
- Current radius arm drop brackets cut off...I have new radius arm brackets to be attached and welded.
- Both rear body mount holes fixed...they are starting to thin and pit.
- Current coil buckets & front shock mounts cut off and replaced/welded...I have the new brackets. (Looks like PO dropped them at some point)
- Drivers side front body mount needs replaced/welded.
- Front frame horns repaired (previous owner welded braces on for front bumper)
- Steering box spacer plate welded to the frame
- Overall general inspection of any other areas needing repair (two minor rust pinholes in lower rear frame horn)
